Fan stopped spinning and at a brick wall
Old 10-25-13, 08:20 PM
T
I bought a replacement motor, starter cap, and still when the AC is turn on, the fan doesn't spin. Cold air is coming into the house but not much. I checked the voltage coming from the thermostat and it shows 24V. The energized switch is closing when ac is on and I measured 120V from chassis to both Line terminals. It is an airflow system and I'm lost. Any thoughts or ideas are appreciated.
Old 10-25-13, 08:52 PM
Received 3,986 Upvotes on 3,578 Posts
Welcome to the forums.
Check the wiring where it connects to the control box inside the furnace/air handler....... look for terminal G. It should have a green wire on it. Try touching a jumper wire from the G terminal to the R terminal and see if that starts the fan. If you have the blower door off you will need to hold the safety switch in.
If the blower starts you have a thermostat problem or the wiring going to it.
Old 10-26-13, 06:37 PM
T
Problem solved. One of the 30A fuses was blown. There was so much paint covering the box that it was difficult to open.
