A/C compressor will not shut off
Old 02-02-14, 08:26 AM
My A/C compressor turns on as soon as the breaker is turned on, even with the system set to off. I suspect a bad thermostat, but I'm not sure. Also I'm not too familiar with digital thermostats. The last time I worked on gas furnaces, everything was mercury switches. It is a Trane XR-13 system and a Trane thermostat.
Old 02-02-14, 09:27 AM
Welcome to the forums.
With the thermostat set to off..... I doubt it's bad. Most electronic thermostats unsnap from a wiring wall plate. Did you try that ?
It sounds more like you have a stuck/burned contactor in the outside unit.
Are both the compressor and outside fan coming on ?
Old 02-02-14, 09:38 AM
Yes they are both running
Old 02-02-14, 10:11 AM
Did you try removing the thermostat from its base ?
If you did and the outside unit is still running.... you'll need to focus your troubleshooting on the compressor unit as it sounds like a contactor issue.
