replaced with honeywell RTH7500D and now blowing hot air?
Old 02-05-14, 04:58 AM
R
I replaced the non-programable themostat with a programable, have done this a few times before, including when i lived in another unit in this building and no issues.
red to red
green to green
yellow to yellow
the white wire on the old themostat was hooked to O so I put it there...
now when the compressor kicks on, I get warm and and an electric heat smell...
tried hooking the white wire to aux instead and got the same thing.
on the old themostat it did look like the yellow wire was screwed into Y but was also screwed into "W" not sure if that was by accident or not, so even tried a jumper so the yellow wire was touching Y and Aux and still no luck..
any ideas before I pull out the credit card and call a pro?
Thank you in advance!
Old 02-05-14, 06:46 AM
R
update
finally gave in and put the old thermostat back and a/c is blowing cold...
so i know it's not the system... either it's the thermostat itself or something I had wired wrong..
old thermostat
Red goes to the RH with a bridge to RC
White goes to O
Yellow goes to Y and W
Green to G
one thing I did notice that I didn't see before wrapped around the wires is a blue wire that was never connected to anything...
could that have been the issue? that on the old thermostat it wasn't needed but on the new one it is?
Old 02-05-14, 08:43 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
You correctly wired the thermostat the first time but failed to configure thermostat option 170 to 2 to match your system. (Heat pump without Aux heat)
Old 02-05-14, 09:27 AM
R
all that because i didn't flip over and see step 12a... ugh!!!
Any ideas what the blue wire they don't have connected might be and if I should connect it to the new thermostat?
Old 02-05-14, 09:48 AM
Houston204's Avatar
I would connect the blue wire to "C" (common) at the air handler and at the stat and lose the batteries.
