X13 ECM to PSC Blower Motor Conversion
Old 04-23-14, 03:08 PM
H
Question X13 ECM to PSC Blower Motor Conversion
Hi, I have a Carrier heat pump air conditioner in my home. Last week the fan blower motor stopped working. I called an AC company and the technician said that the blower motor needed to be replaced. Because it was the X13 ECM motor it would cost $1,100 to replace it. I cannot afford that, so after doing research online I saw that you can replace the ECM motor with a PSC motor. I found a video on Youtube that shows a AC technician changing the motor. https://www.youtube.com/watch?v=eTfM8_Oa1HQ
I went to Grainger and purchased a AO Smith PSC motor and a capacitor. I installed it and wired it, but when I turn on the circuit breaker the blower motor runs continuously and the digital thermostat is blank. I must have wired something wrong. Any advice please?
Old 04-23-14, 04:06 PM
Bob14525's Avatar
Received 27 Votes on 22 Posts
Henry, it's too bad you didn't post your initial problem here before purchasing the new motor & capacitor. There's a good chance that you can repair your old ECM motor (assuming you're handy with a soldering iron). The majority of the time, a thermistor in the motor control module (bolted to back of motor) goes bad and costs less than $2 for a replacement part. See link below for more information.
http://www.doityourself.com/forum/ai...ble-motor.html
Houston204's Avatar
Received 17 Votes on 14 Posts
Post the complete model number of your air handler.
Old 04-23-14, 04:27 PM
H
It is a Carrier FC4DNF036000AAAA
Old 04-23-14, 04:31 PM
H
Hey Bob, I saw the link about the motor control module, but I was unable to find it on my ECM motor. The electronic part of the motor is covered with a thick black rubbery insulation.
Old 04-23-14, 05:37 PM
Houston204's Avatar
The ECM X13 is different from the ECM 2.3.
originally...
http://i151.photobucket.com/albums/s...ps294b84a7.jpg
with changes...
http://i151.photobucket.com/albums/s...ps99c226fd.jpg
The brown and blue wires to the ECM X13 motor were low voltage. You probably damaged the transformer if you connected them directly to the new motor.
Old 04-23-14, 05:43 PM
H
Would that be the thermostat transformer? Would that cause the problem I am experiencing with the continuously running motor?
Old 04-23-14, 05:48 PM
Houston204's Avatar
Transformers cost a small fraction of the price of a motor. (The blank stat)
http://i151.photobucket.com/albums/s...ransformer.jpg
You also need to order a 24 volt fan relay (to have control over the fan motor)
Grainger is more expensive but faster than Amazon if you can walk into a building.
Old 04-23-14, 05:53 PM
H
Would they know the part that I need if I give them the model number of the air handler? Thank you Houston, you are a step ahead of me.
Old 04-23-14, 05:55 PM
Houston204's Avatar
The Grainger 6ACH5 fan relay will work.
You can get away with a smaller single pole relay but I am getting much more reliable operation from the double pole double throw relays.
Old 04-23-14, 05:59 PM
H
Thumbs up
Thank you so much Houston! I really appreciate the help! I will get the parts tomorrow.
Old 04-23-14, 06:03 PM
Houston204's Avatar
That transformer picture may be 6 or 7 years old. The price has probably gone up.
Post back before applying power to the new transformer.
Some models use black for high voltage common and some use white.
Orange and red are the second high voltage leg depending on if you have 208 or 240 volts to your unit.
We will need to verify the connections to avoid another trip to the store.
Old 04-23-14, 06:08 PM
H
That's okay. Thank you again!
Old 04-23-14, 06:42 PM
Houston204's Avatar
You will also need some wire nuts.
Old 04-23-14, 09:36 PM
H
I will post back as soon as I get the new parts.
Old 04-24-14, 12:34 PM
H
Hi Houston, I went to Grainger and they had the transformer in stock. The fan relay had to be ordered and I will be able to pick it up tomorrow morning.
Old 04-25-14, 02:31 PM
H
I have both parts and wire nuts. :helpme 2:
Old 04-25-14, 05:37 PM
H
This was the original part. Was it the transformer and relay all in one? It looks like a combination of both new parts I purchased.
Old 04-25-14, 06:26 PM
Houston204's Avatar
Nope, that is just a transformer.
The relay is something that we are adding to have control over this PSC motor.
You are replacing an existing transformer and adding a relay.
The new relay is in my second diagram but not the original diagram
Looks like you were wired to the 230 volt post on the old transformer.
Can you tell which two high voltage wires on the new transformer you will be using to use 230 volts?
Post a pic of the new transformer if you are in doubt.
Old 04-25-14, 06:39 PM
H
I am thinking the red and the white?
  #21
Old 04-25-14, 06:45 PM
Houston204's Avatar
I cannot read the top of your new transformer to assist you from that picture.
  #22
H
These are the wires that are there.
  #23
Old 04-25-14, 06:48 PM
H
I hope these are clear enough.
  #24
Old 04-25-14, 06:50 PM
Houston204's Avatar
Air handler yellow and black are high voltage.
Air handler red and brown are low voltage.
Cap off transformer red and cap off transformer white individually.
Transformer black and orange are high voltage.
Transformer yellow and blue are low voltage.
Where is the blue wire that went to your old motor?
Do you have spade connectors and a crimper?
  #25
Old 04-25-14, 06:55 PM
H
Capped off transformer red and capped off transformer white individually.
The blue wire is connected to the SPT. I don't have the spade connectors, but I can run to Home Depot. It is 1 mile from my home.
  #26
Old 04-25-14, 07:00 PM
Houston204's Avatar
Please define SPT.
Smells like my spaghetti is on the table. I'll be back in a little while...
  #27
Old 04-25-14, 07:03 PM
H
This is the SPT in the handler.
  #28
Old 04-25-14, 07:05 PM
Houston204's Avatar
That wire feeds the coil on your new relay. It will not connect to the new transformer.
If you post a pic of the top of your new relay I can assist you in its location.
Is your transformer R wire blue or red?
  #29
Old 04-25-14, 07:07 PM
H
Okay, enjoy your spaghetti.
  #30
Old 04-25-14, 07:12 PM
H
This is the top of the relay.
  #31
Old 04-25-14, 07:39 PM
H
Is this the red R wire you were asking about?
  #32
Old 04-25-14, 07:45 PM
Houston204's Avatar
The 2 bottom terminals of the relay are the 24 volt coil. One of them will connect to SPT with the blue wire and the other will connect to the brown 24 volt common wire. (the terminals are actually double up)
The 2 top terminals of the relay will connect to the black high voltage wire and your fan motor speed tap (a black for high speed or blue for medium speed wire) as shown in my second diagram.
Okay, so transformer blue connects to air handler red and transformer yellow connects to air handler brown.
Air handler black connects to transformer black and transformer orange connects to air handler yellow.
  #33
Old 04-25-14, 07:51 PM
H
The motor has 3 speeds. Should I use the medium or low speed? I think the red is the slow speed. I need the spade connectors, but I can get them later.
  #34
Old 04-25-14, 07:53 PM
Houston204's Avatar
I'd use blue medium speed.
Cap the other two speed wires individually.
I have seen people melt relay terminals by trying to wrap motor wires around them instead of using spade connectors.
  #35
Old 04-25-14, 07:55 PM
H
Is the brown 24 colt common wire the same as the air handler brown?
When I have to use the same wire could I use a wire splicer?
  #36
Old 04-25-14, 08:01 PM
Houston204's Avatar
Yes. In post 22 I see 2 brown wires going into a single spade connector for the transformer.
I'd say that one of these wires went to the control board and the other went to the old fan motor. That is the wire that will now feed the fan relay.
  #37
Old 04-25-14, 08:06 PM
H
So after the brown wire goes into the transformer I can just connect the extra brown wire to the yellow transformer wire?
  #38
Old 04-25-14, 08:08 PM
Houston204's Avatar
No. The black transformer wire is high voltage and the brown air handler wire is low voltage.
  #39
Old 04-25-14, 08:09 PM
Houston204's Avatar
Hang on. I'll provide a pic...
  #40
H
Sorry, I meant to say brown to yellow.
