Just installed ductless A/C 18000 btu .... Runs perfect Line temp question ?
So I have more experience with aircraft and cars 134A . This got a proper install and extra length line weighed in charge ( 25ft to 36ft ). Super cold inside down to 35 F max R410a .
My question is the vapor and liquid line seem cool . high side is 70 f the low is 45 f , 90 f outside .
Most of my work has a large difference a real hot and cold when running hard . My condenser has a good 10 degree air temp difference from inlet fan to discharge .
I feel like burping an ounce into the recovery machine , Now fall into don't fix it , if it aint busted . Compressor current is normal . Whats your call ? Should the high side be hotter ?
Thanks Heli
Thanks Heli
Received 38 Upvotes
I'm not an expert on mini splits. But I believe both copper lines are are actually low side.
Well , according to the paperwork it shows a low and high side . I haven't done a mini split install of this type before . It shows good numbers for temp and pressures for the indoor and outdoor unit . The asian or euro units need a 5/16 to 1/4 adapter to use R410 gauges / hoses , that can be found on eBay / some locals. That R410 can run 300 + psi on the high side .
Just seems odd not to have a hotter high side . I was going to post a video for others to see the how to . I think the easiest DIY would be the stock line set , with only a vacuum pump needed on a smaller 110 volt unit 9000 - 12000 BTU . Keep the power bill low just cooling an office or bedroom .
You could pull down a vacuum and opening the charge valves ( pre charge unit ). While these smaller units use aprox. 1000 watts or under .You could use an outdoor 110 V plug . Its better to have circuit just for the unit a low use circuit to a patio or garage would handle it .
