PTAC compressor not working
Old 05-15-14, 05:34 AM
Hello everybody
Thank you already for your help.
I have a Amana trough the wall PTAC heat pump air conditioner. How would I check if my compressor is bad. I checked the capacitor with multi meter and everything is ok. Can I check the compressor itself too?
Old 05-15-14, 12:45 PM
Received 3,745 Upvotes on 3,359 Posts
Welcome to the forums.
You could check the compressor for the supply voltage of 120/240vac. If the power is present on the compressor than the compressor may be bad.
