Compressor not kicking in
Old 05-15-14, 05:17 PM
W
So i have a central air unit made by goodman. Ive has compressor replaced about 3 yrs ago. I wasnt previous owner. Last year i started noticing this and its happening once again. When i turn the unit on for first time. Meaning its been off couple days or was on heat. The compressor fan spins but the unit isnt actually blowing cold air. After a bit it then kicks on. What i did a few times was i actually turned breaker off assuming maybe power glitch and don't know if coincidence but has worked. Last week i tried that didnt work but like with a minute or two later it kicked in cold air. Any idea. Could be bad thermostat?
Old 05-15-14, 05:35 PM
Bob14525's Avatar
Received 77 Upvotes on 68 Posts
If you're seeing the condensor fan running (outdoor unit) it's not the thermostat or contactor. If either of them were bad, the outdoor unit wouldn't be running.
Old 05-15-14, 05:42 PM
Received 3,891 Upvotes on 3,488 Posts
Welcome to the forums.
Is this a straight air conditioner or a heat pump system ?
Old 05-15-14, 05:55 PM
W
Its got both heat and air. The fan does spin outside but its not cold inside. Then you hear the noise like compressor kicked in and becomes cold air.
