Outside Unit Not Kicking On
Old 05-22-14, 02:20 PM
G
The compressor and fan on my central air unit will not kick in. When the unit comes on the fan does not, but I can hear a hum from the motor. If I start the fan moving it will continue to run. The compressor, however, also does not come on. I replaced the contactor and now it tries to kick on, but still will not. Any ideas?
Old 05-22-14, 02:43 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Replace the capacitor. If you check it, you may see a bulge on the top or sides or some oily substance on it.
Get the same specs as whats there, though you can go a higher voltage...not lower. Make a diagram or take good pics so you can connect the new one correctly.
Old 05-22-14, 03:21 PM
G
Thanks. When I looked at it, the top of it is bulged out. I'll give that a shot.
Old 05-22-14, 03:28 PM
Gunguy45's Avatar
Super Moderator
Yep, that should fix it up. your contactor was probably fine....
Old 05-27-14, 03:23 PM
G
Purring like a kitten now.
