Blower fan as whole house fan?
Old 05-27-14, 11:20 AM
D
Here's a nutty question. Has anyone tried using a squirrel cage blower fan as a whole house fan? I have no attic space and was and the windows are 22 inches wide, so I was thinking of a blower fan (like the attached image), with a baffle, sized to the window opening, might do the trick. And, if that works, maybe even enclose the fan in an a mdf box (with holes of course) to add a layer of noise dampening. I welcome all and any suggestions.
Thanks in advance!
Greg
Old 05-27-14, 11:33 AM
Received 3,627 Upvotes on 3,251 Posts
It would work but not move anywhere as much air as a 24" or 30" whole house fan.
Old 05-27-14, 11:38 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
It works. But a AHU fan will not move enough air. You will need to step up to one of those floor fans. It still will not be like having a hole house fan but close.
Old 05-27-14, 11:41 AM
Oh I see that you are in PA! I would not recommend this in green grass climates.
Old 05-27-14, 01:28 PM
D
Wow, thanks for your quick replies. Currently, the only thing I have is a 20 inch box fan that I stick in the window. I guess my first goal is to cool down this 550 sq foot 3rd floor space. Since I can't fit one of those big, 20 inch Air King fans, I'm hoping there might an alternative. BTW, the blower says it moves about 4000 cfm vs. 3650 cfm the Air King which bills itself as a whole house fan. No clue on the noise difference. Your thoughts?
