Air Conditioner no running right
Old 05-28-14, 07:17 AM
I have a Goodman outside AC unit; a few days ago I notice the house was warm and not reaching the desire temperature after curiously looking at the functions of the air handler and the outside unit, I notice that the air handler was never turning off due to the house never reaching the temp on the thermostat but the outside unit was turning off and on every 10 to 15 minutes also notice that while the unit outside was On the air on the vents were coming out cold.
Old 05-28-14, 07:26 AM
Gunguy45's Avatar
Super Moderator
Is the fan outside running or just the compressor? Are the coils outside clean?
No Pro, but I'd suspect a temp or pressure issue in the system that is cutting off the compressor.
If the fan is running and the coils are clean...prob something with pressure, which you won't really be able to check.
Received 345 Votes on 323 Posts
Welcome to the forums.
When the outside unit came on.... was the fan on top running ?
Was it moving a lot of air ? Is it making any unusual sounds ?
Old 05-28-14, 08:23 AM
sounds fine when it comes on and the fan does run. When it shuts off the compressor and fan both stop running but the inside blower stays on as the temp has not been reached
Old 05-28-14, 08:53 AM
It's possible it could be a pressure switch activating in the compressor unit. The low pressure would activate if you were low on refrigerant. The high pressure would activate if you had a possible airflow problem inside.
Be sure to check the filter(s).
Old 05-28-14, 08:56 AM
user 10's Avatar
Received 30 Votes on 25 Posts
Could you post the model of your outdoor unit?
It may have pressure switches to prevent operation when there refrigerant pressure is too high or too low. (you'll need to call someone to throw gauges on the unit)
There could also be a low voltage wiring issue.
Old 05-28-14, 09:00 AM
The filter is brand new and the air comes out of the vents just fine the model is a Goodman GSX130301
2.5 Ton, 13 SEER Condenser, R-410A Refrigerant
Old 05-28-14, 10:12 AM
Your unit could have a high pressure cutout. Try cleaning the outside coil.
Old 05-28-14, 10:50 AM
The outside coils are completely clean
Old 05-28-14, 11:03 AM
If you know how to use a multimeter, you can open the condenser panel and check the 24V at the contactor terminal and also at the entry point of the condenser to find out if and where the 24V was stopped.
Old 05-28-14, 04:21 PM
One more thing, be careful on those contactor terminals, HIGH Voltage ...
Old 06-05-14, 08:22 AM
had a tech come over and check my system out he said everything was fine that when the outside unit was turning off it was going in its energy mode and that the problem was that when it cutoff it was pulling the hot air from my upstairs and displacing it throughout the house he suggested a thermostat that didnt shut off the outside unit and possibly closing the return thats on the second floor. Any thoughts????
Old 06-05-14, 09:13 AM
That is not someting your system has according to the service manual. Do you have an electric utility installed energy saver system ? That would be a unit where you would save money and allow the power company to shut off your compressor in case of high useage days.
Your outside unit doesn't have a low pressure switch.... just a high pressure one.
I'll wait for your reply but it doesn't sound like the service tech what was happening.
Old 06-05-14, 01:38 PM
HVAC RETIRED's Avatar
Get a relative humidity gauge for indoor humidity readings.
Check the temp from the nearest supply register compare it to the room air-temperature.
Check the air temp off the outdoor condenser compare to outdoor temp.
This will provide us with a lot of clues.
