Trane xr 13 A/C outside fan stopped and this morning came back on am
Old 05-31-14, 03:22 AM
Have a Trane xr 13 A/C unit (3 years old) and today the fan motor outside stopped working.Found some water in the line that drains outside(small clear tubing),turned all breakers off tothe house and back on,checked 30 amp fuses(seemed fine)played with thermostat trying to go through various methods like auto and manual set,and the fan outside to the A/C is dead-nothing.So,I turned the unit A/C off went to bed and this a.m. the A/C and fan outside is working?OK.....what did I do?My guy who put it in won't return my calls.The fan to the furnace(heat) always worked but would'nt pull temperature down because the A/C was dead.Now it is working and has already gone from 80 degrees to 74 in 30 minutes or so.Advice on what to do would be appreciated.On the downside the filter was a 90 day filter but after 35 days it was pretty dirty.Will replace today.
Old 05-31-14, 08:46 AM
If it is working, not much you can do, just wait and see.
