Trane XR13 fan always on second stage
Old 06-08-14, 01:10 PM
Trane XV95 with XR13 air conditioner, just got the ac unit installed. When it's trying to maintain temp should it always be on second stage (high)? I can understand if you drop it by a few degrees, but should it not run on the low setting? I only have a single stage tstat, not sure if that matters with cooling. Also I think my dip switches may be wrong for the tonnage of my ac, does it make a difference? Any help would greatly appreciated.Name:  _20140608_160600.jpg
Old 06-09-14, 06:54 AM
Figured it out, had a look on the back of the furnace door and my dip switches were wrong. Switches 1 and 2 were set for a 3 ton unit. I also changed switches 3 and 4 to change the CFM from normal to low. Now it doesn't sound like a jet taking off when the fan kicks on. Hopes this helps somebody else
Old 06-09-14, 09:33 AM
Received 331 Votes on 309 Posts
Your installer should have taken care of that.
Old 06-09-14, 09:56 AM
without a doubt, when the furnace was installed they only put a single stage tstat in too.
