Installing Honeywell WIFI thermostat
I am trying to install a honeywell WIFI thermostat and have followed the directions as given. I did not have a C wire so I used the G wire setup by running a jumper from G to Y. As I turn on my system now I can't get my fan to run. The outside condenser is running though and does not shut off.
Welcome to the forums.
Is the top picture a before or after picture ?
You have the green wire on the G terminal.... not C.
