outside AC unit is not cooling, makes a buzzing noise every couple minutes.
My central air conditioning unit is not cooling. I went to check the outside unit, and the fan is spinning, but I can't tell if the compressor is turning on. But every couple of minutes it makes a buzz noise.
A couple of weeks ago, my breaker box got wet, were not sure how, but a lot of the breakers were full of water. Since then the AC breaker made a loud buzzing noise in the same intervals as the outside unit. We replaced the breaker, and the buzzing inside stopped, but the outside unit still makes a buzz noise, and the air in the house is warm.
I just wanted to know if there was a way to fix this myself, or if I should just give up and call somebody. Normally my dad would be able to fix this, but he's currently away for a couple of months and I'm here by myself. I have a little experience working with window units, but never with central units, so my knowledge is minimal. So if it's much too complicated, I may not be able to do it myself.
