Lots of water leaking from HVAC drain pipe
Old 06-19-14, 06:49 PM
N
The drain is doing it's job, but there's some serious water coming out of the pipe outside. I probably wouldn't have noticed, but the drain pipe comes out on the roof of the patio, so obviously a steady flow of water isn't convenient.
Is it normal to have a significant drip (would fill a 5 gallon bucket in an hour or so) or is there something wrong?
Thanks in advance for any help!
Nick
Old 06-19-14, 06:54 PM
T
Received 31 Upvotes on 25 Posts
The system is doing its job and removing the humidity in the house. It might be possible to direct the drain to a better location.
Old 06-19-14, 07:35 PM
Tolyn Ironhand's Avatar
Received 786 Upvotes on 666 Posts
I know a guy that forgot to turn off his humidifier on his furnace/air handler since winter. When the fan turned on the water valve would open. Maybe you have something similar? Swamp cooler?
Old 06-19-14, 07:37 PM
N
No, central air. Just had a new condenser installed, but the old one was doing the same thing.
Old 06-19-14, 07:40 PM
N
@tomf63 - That was my plan, but I wanted to make sure there wasn't a bigger issue.
