Lennox Central Air Issue
Received 0 Votes
Yesterday our central air system stopped working. The blower fires up ok. Changed the batteries in the thermostat and cleaned out the clean out and filter is ok. I reset the Breaker. Condensor outside does not fire up. Any recommendations. Thanks
Welcome to the forums.
You pushed the breaker all the way to off and then to on ?
There should be an outside disconnect right next to the compressor unit. It may have fuses in it.
Your next step is to use a meter and check for 240vac at the disconnect.
