York diamond 80 blower problem
Received 0 Votes
Hello, I woke up this morning to the a/c compressor running but the blower was not. If I turn the thermostat off and turn the fan on it still does not run. However in heat it works as it should.
It is a York diamond 80. Any thoughts or ideas?
Thanks
Thanks
Received 0 Votes
Just a little more info.
It is hooked to a White-Rodgers digital comfort set 2 thermostat.
The unit mfd is 02-96.
It has not had many problems since I have had it. I did have to replace the fan about 6 or 7 years ago. I did that because it had cracked and was making noise. Also had to replace the flame sensor in the furnace several years ago. But that is all the issues I have had in the past.
Are you measuring cool to neutral?
The cooling speed relay has failed.
If you look behind the control board at the cooling speed relay you will probably see damage.
You can disconnect the 2 wires from the furnace Y terminal and twist them together for temporary cooling with the heating speed.
Received 0 Votes
That's what I was afraid of. You said I can disconnect the two wires from the Y terminal in the furnace and twist them together for temp coll on heat speed.
Are you referring to the light gauge wires? See picture.
Received 0 Votes
Another thing I have noticed while studying the wiring. The heat and cool terminals on the control panel are jumped together. The wiring diagram states these two are jumped from the factory.
I can hear a click inside the control panel when I turn on the a/c. Is that the cool relay or is it the signal to the outside unit?
I would get a Y spade connector and move the cooling fan wire to the Line terminal along with the wire currently there.
Unplug the Heating speed wire and secure it so that it will not short against anything or plug it into a Park terminal.
Received 0 Votes
Ok, the fan is hot wired and running, a/c is on, and cold is blowin.
Whew that feels better!
I have looked at new control panels online, but first I will call a few places nearby tomorrow (sooner is better).
Thanks for all your help. I will post how it turns out with the new control panel.
Received 0 Votes
I got the new furnace controller today that I had bought off Ebay. It is not the same model as the original is no longer available, but it is interchangeable with mine. I swapped them out and everything is working great.
Thank you for your expertise and assistance in troubleshooting and advise on how to keep it cool while waiting on the parts!
