A/C outside fan not spinning
Old 06-22-14, 11:34 AM
We have replaced the outside fan and motherboard which got the outside fan to to spin for about an hour then it stopped. The inside unit turns on, but will not blow any cold air. Any other suggestions?
Separated from...... http://www.doityourself.com/forum/ai...-not-cool.html
Old 06-22-14, 12:18 PM
Houston204's Avatar
Did you prove that these parts were required before replacing them?
Do you have a volt meter?
Old 06-22-14, 12:30 PM
The guy who installed our AC unit 5 years ago replaced these parts. The outside fan started, but hours after he left, the fan stopped running.
Old 06-22-14, 12:34 PM
Yes, we have a volt meter
Old 06-22-14, 12:47 PM
Houston204's Avatar
Post the make and model number.
Old 06-22-14, 04:36 PM
It's a Rheem Prestige Super Quiet 80 Two Stage. I'm not sure where to find the model number.
Old 06-22-14, 04:46 PM
The Model number is RCQD-4821AS.
THANKS.
Old 06-22-14, 05:04 PM
Houston204's Avatar
http://cdn.globalimageserver.com/fet...ication-sheets
You posted the model number of an evaporator coil.
A super quiet 2 stage 80 sounds like a furnace.
Did you want help with an outdoor unit?
Old 06-22-14, 05:24 PM
Yes, outdoor unit. Sorry about that. The model # is RARL-048JEZ. Thanks again.
Old 06-22-14, 05:51 PM
Houston204's Avatar
Old 06-22-14, 06:00 PM
Where would I look for the trouble codes?
Old 06-22-14, 06:09 PM
The trouble code currently noted is L 23.
Old 06-22-14, 06:46 PM
Houston204's Avatar
Did you replace the dual capacitor?
Old 06-22-14, 06:54 PM
Does the capacitor look like a silver round canister? If so, yes. He also replaced the circuit board inside.
Old 06-22-14, 07:01 PM
Houston204's Avatar
Post the wires connected to C, Herm and Fan.
Old 06-23-14, 07:09 AM
Here's some pictures
Old 06-23-14, 05:31 PM
Houston204's Avatar
I can't make out the connections on the dual cap. Can you post the connections?
Old 06-24-14, 05:26 AM
Houston204's Avatar
How many wires does your condenser fan motor have?
Old 06-24-14, 02:53 PM
Not sure how to describe the wiring with text, so here's a video
Wire connection: Wire connection - YouTube
Old 07-23-14, 06:39 AM
Just to add a conclusion to this, we got it fixed. The problem was the wrong fan motor was used as a placement causing the thermal overload to shut the unit of. We got the correct motor from Rheem & now all is good. Thanks for your time & help Houston204
