Gibson package unit blowing little air into house. Help!
Received 0 Votes
So, I have been working on my central air unit. My problem this time is that there is little airflow coming through the vents in my house, all of them the same. I took the panel off by the blower and made sure everything was clean. I then noticed that while the panel is off, there is much more air flow through the house. I thought it could then be that there was something constricting the airflow in the return duct, but my husband checked it out and said nothing was there. What am I missing?
I'd say you have a clogged filter somewhere. Either that or a crushed return duct.
Friend of mine lived in a house for 5 years, never knew there was a filter in the unit that needed changing.
Have you looked at all the return grilles for a filter?
Received 0 Votes
Yes, we have. The house sat vacant for 10 years before we started fixing it up again. The duct work was put in about 2 years ago when we first got the place, and the system has not been run, so as for right now there are no air filters. I was trying to get it working first before I went and picked some up.
Can you get to the dirty side of the evaporator coil? (item 34)
It is opposite the blower side of the evaporator coil.
http://www.foxmacon.com/nd/models/GR4GA.pdf
Looks like you have a small door in panel 9 that will let you see the dirty side of the coil.
Turn off power and clean it with some simple green and a water hose.
Home Depot has a nozzle like the Bullseye that can focus into a very small stream . I use the Bulls Eye from Johnstone but this one uses the same 3 ball bearing method for controlling the stream well enough to practically sign your name on a sheet of paper.
I always pop the top and the coil is always dirty.
I sometimes use a stick of pvc to prop it open if one is side sealed with tar or mastic.
Use a large trash bag to keep water off of the blower motor.
