Need help determining single or double pole contactor
Old 06-24-14, 08:15 PM
I
Received 1 Vote on 1 Post
I would know if I saw it again but can't remember 100%. Reason I ask is I need to get this part but won't be able to get to the house to see it and need to change it out tomorrow evening.
This is a Trane outside AC unit, no heat..has gas. Model # TTR042C100A0
I'm almost certain it was a single 30A but can you tell by the model #?
Thanks....I know I could buy both but likely cannot return electrical parts.
Old 06-24-14, 08:38 PM
Received 2,797 Votes on 2,533 Posts
Old 06-25-14, 03:18 AM
W
If at all possible , I replace with a 2 pole contactor and if there is enough physical room ( there usually is ) the next size up in ampacity .
Such an upgrade cost me very little more and it is hoped will last longer .
A 2 pole contactor may wire SLIGHTLY differently . But no big deal .
https://www.johnstonesupply.com/stor...ep?pID=L45-038
The web sire shows contractor cost at less than $ 10 .
God bless
Wyr
