A/c will only run when t/stat set to on position
Old 06-25-14, 10:04 AM
H
I have what I believe to be a Coleman/York Furnace, Model # G8T08012UHA11A. The a/c unit (outside) will not function if the t/stat is set to AUTO, however, it runs fine when set to the ON position - ie: if I set the temp to 70 the unit cools the house until it reaches that temp, the compressor shuts down and the fan continues to run. We believe the t/stat is ok, however, it is using batteries like crazy, so my hubby thinks we should replace the board inside the furnace, part #031-01267-001. BTW, the heat works properly when set to AUTO position...Any recommendations? Should we try to replace the t/stat first? Thanks in advance.
Old 06-25-14, 10:21 AM
Bob14525's Avatar
Received 20 Votes on 15 Posts
I'm suspicious of the thermostat itself, particularly because it's very hard on batteries. Most thermostats have small relays that connect the various wires running to the furnace/AC unit. The circuitry inside the the thermostat is not directly connected to the furnace control board. The thermostat circuitry merely controls which relays are enable or disabled.
Old 06-25-14, 10:55 AM
H
Thanks Bob14525...we will try replacing the t/stat first!
Old 06-25-14, 12:44 PM
HVAC RETIRED's Avatar
I am wondering how the thermostat could ever have been wired so that situation could happen...
Old 06-25-14, 01:53 PM
Setting the stat to AUTO should have no effect on the condenser.
