Vertical Air Handler Sweating/Leaking
I have a Vertical Air Handler. The Blower Motor was replaced and ever since then, there has been water sweating or leaking underneath. It sits on a frame that has drywall. The drywall is damp, not pooling water. I checked both drainage pipes the main and secondary and both were fine. I have a feeling it could be the fan speed. It is plugged into fan speed 2 (1-5 options), the same as before. Any suggestions appreciated. Thanks, James!
I don't think the fan speed is related to the water problem. Check to see if the AHU was knocked out of plumb by the blower motor installer.
