Ac tech added freon today but it's still not cooling......
Old 06-28-14, 09:12 PM
R
So I had an ac tech come out today and he added freon to my system it has a very small leak he said. Well the system still won't cool my town home down to desired temp. It keeps bouncing between 75-77 and it's getting frustrating. I want it to cool down to 73. The thing goes from blowing ice cold air to then Ok cool. Any ideas on what's wrong or how to resolve this?
Old 06-28-14, 10:54 PM
R
So much just noticed that the ac compressor starts for maybe 20 secs then shuts off. Also tech said he added 3lbs of freon get the feeling I got totally ripped off. It's a good man unit.
Old 06-28-14, 11:22 PM
Received 3,880 Upvotes on 3,477 Posts
Welcome to the forums.
Your unit has a low pressure sensor and will shut the compressor down if low on refrigerant.
An EPA certified tech is not supposed to knowingly charge a leaking system. He is supposed to determine the source of the leak first. It sounds like your system may have more than a small leak.
Old 06-29-14, 02:37 AM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
I wouldn't be surprised if you can hear this leak.
Old 06-29-14, 02:56 PM
R
i got totally ripped off. It was a clogged drain line or whatever you call it and fixed it with my vacuum cleaner thanks to my good friend.
Old 06-29-14, 03:10 PM
You are describing two different problems here. Make sure you know exactly what the problem is before you start shouting uncle.
