Fan running backwards, but not all the time...ideas?
Old 06-28-14, 08:12 PM
C
Unhappy Fan running backwards, but not all the time...ideas?
Hi:
My compressor fan will run backwards from time to time..but when it reaches the desired temp and the thermostat cuts off and then cuts back on its 50/50 if the fan will run forward or backwards. If it runs backwards then I can turn the unit off and then back on and it will usually change directions. Any ideas?
Thanks in advance,
Chris
Separated from........... http://www.doityourself.com/forum/ai...backwards.html
Old 06-29-14, 12:18 AM
Received 3,880 Upvotes on 3,477 Posts
Welcome to the forums.
What is the make and model of your outside unit ?
It may be a defective start/run capacitor on the fan motor.
Old 06-29-14, 02:35 AM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
I have replaced the run cap with this problem before and had to return and replace the motor within a week.
Run caps are cheap and it would be worth trying only the cap first.
