AC condensate pump won't shut off
Old 07-04-14, 02:11 AM
It's a holiday weekend and the AC condensate pump will only shut off when I unplug it. It's very loud. Will it hurt for it to run all the time or for it to be unplugged until Monday? Thanks.
Old 07-04-14, 04:50 AM
Received 194 Votes on 180 Posts
I would not let the motor run continuously especially when dry. The motor may overheat.
Try giving the tank a cleaning. Sometime "snot" develops inside that can prevent the float from moving freely (if you have a float switch type tank). If cleaning does not get it working try taking the cover off the motor compartment and see if dirt or anything is jamming the float switch.
Old 07-04-14, 04:59 AM
pugsl's Avatar
Received 20 Votes on 19 Posts
With a nosiey and probably a stuck float If you can't clean it up and get it working right I just went to lowes site and they have them in stock. The nosiey part is more worrisome than stuck float. mine is so quite I never know when it runs.
