Plastic bag sucked into filter duct
Old 07-04-14, 04:56 PM
Changing the filter a plastic bag sucked up into the duct. I looked up the best i could and could not see it. If I run the AC will the bag cause it to over heat? Also what can i do to get the bag out of there. I plan on turning the ac off tonight and taking off the panels too see if i can find it. Thanks for the help in advance!
Old 07-04-14, 05:00 PM
Most likely it's in the blower. Might have to pull the blower to get it out.
Old 07-04-14, 05:10 PM
Thanks for the reply i can hear the bag so thats what i was thinking, its a goodman AC so what would be my best bet of getting to the blower if i take of the front panel would that give me access to the blower
Old 07-05-14, 05:06 AM
You did not say what type of Goodman unit you have but make sure you pull the disconnect or turn off the breaker for your AC. The AC is controlled by a thermostat so it can turn on by itself. Keep in mind that you may have two disconnects. One for the outdoor unit and one for the interior air handler.
Old 07-05-14, 08:39 AM
The blower is usually in the bottom section. There should be 2 screws holding the blower in place. Then it just slides out.
Be sure and follow Pilot's instructions.
Old 07-05-14, 12:38 PM
thanks guys ended up taking off the front panel last night and pulled it out working like a chemp now!
