Lost almost 18 lbs R410a from cracked reversing valve due to vibrations
Old 07-11-14, 04:04 PM
B
My wife and I now need almost 18 lbs of R410a replaced.
This is the SECOND time in 14 months that the reversing valve of our Amana/Goodman unit cracked from vibrations.
We were given price of $45/lb not including labor..total refrig cost of $801.
Very upset...
Tried to get some more information and asked a lot of friends (a couple are union) and was told about a company that sells a 25 lb tank of R410a for $119.
Is this possible?
I'm going to talk to the service guy about this.
If he claims that this is not a real deal and won't drop the price, what else can I do?
I suggested to the service guy to install rubber mounts-how is it possible that this not done when the unit was first installed?
Any other ideas or solutions?
TIA-Chris
Read more: http://www.doityourself.com/forum/he...#ixzz37CS4f1JU
Old 07-11-14, 04:43 PM
18 Lbs of 410a? Is this what the service tech told you? Maybe 8 Lbs on a residential unit at the most. $45 is way over priced.
Old 07-11-14, 05:03 PM
Received 3,898 Upvotes on 3,494 Posts
Welcome to the forums.
How old is the unit ?
18 lbs of refrigerant..... not.
$45 a pound..... a tad high.
Might be time to find a new company.
Old 07-11-14, 06:47 PM
T
Check the spec plate on the outdoor unit. It should tell how much was shipped in the unit. Usually enough for a 15' line set and coil. I'd call someone else.
Old 07-11-14, 07:21 PM
C
Received 7 Upvotes on 7 Posts
You can get 30lbs of 410a for $125 all over the country.
Old 07-12-14, 02:15 PM
E
No way the system holds 18 pounds. If someone told you this then they are most likely cheating you.
