indoor fan (A/C) not working
Hi all,
We have a 2 zone a/c and heat (Nat. gas, forced air).
For both zones the outside fans are coming on. The larger copper lines getting cold (with condensation) and the smaller line is warm. I've changed the filters and checked the circuit breakers which are all on.
However the indoor fans for both zones are not coming on. I don't have much as experience with central a/c so wondering if anyone has any suggestions. I might be overlooking something simple.
We bought the house last fall and everything was inspected. At the end of the winter the heating on the upstairs zone was acting up and not coming on at the set temp. Not sure if this is related.
We'll need more information then that !
What does a 2 zone system mean ?
Do you have two compressors outside ?
Do you have one furnaces inside ?
Do you have two thermostats ?
Or.... do you just have two separate systems.... one for upstairs and one for downstairs ?
OK, I should have given more info....
Its two furnaces- one in attic and one in basement. There are two compressors outside and there are two thermostats. Each system is independent - one for 2nd floor and one for 1st floor (+ basement).
Perfect.... and you are telling us that both outside compressor appear to run normally but neither inside blower is running ? That is a pretty odd co-incidence.
Try putting the thermostats into FAN ON mode and see if the fans work then.
You'll need to troubleshoot each system separately.
Yes its a bit of a coincidence which made me think I was overlooking something.
The indoor fans do not come on in the FAN mode! They should come on immediately, or after several second, right.
Then you need to decide which one to work on first. You'll need to open the blower access door and see if the motor is frozen or if the blower will turn when pushed. You can also put the thermostat in FAN ON and then go back to the unit and hold the blower door safety switch in. See if the blower moves on its own or starts with a little push of a stick.
You may just need a capacitor for the fan..... that's the least expensive way to start.
