Compressor Fan spins a few seconds and the breaker blows.
Old 07-22-14, 05:40 PM
A
Any ideas? goodman clt60-1
Old 07-22-14, 08:09 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Turn off power to the outdoor unit at your service disconnect...
Check the capacitors in the unit for a swollen top.
Check for melted wiring in the control panel.
Check the compressor terminals and crank case heater for melted wires.
Measure the capacitors, Measure the ohm reading of the condenser fan motor and the compressor.
Old 07-23-14, 04:14 PM
A
Capacitor has hole in it.
Hi the capacitor has a hole in it and there is a waxy substance pooled at the bottom of the control box. I replaced the capacitor last year with a similar one that the distributor said was the same. So I'm hoping that's all it is. What do you think?
Old 07-23-14, 04:37 PM
A
Please review attached pics, thanks
Size:  30.6 KBName:  CAM00572.jpg
Size:  32.9 KBName:  CAM00573.jpg
Please review the attached pics
Old 07-23-14, 05:13 PM
Received 3,422 Upvotes on 3,068 Posts
I have reviewed your pictures..... your "Made in Canada" capacitor is no good.
Old 07-23-14, 05:29 PM
A
soooo....what's a better brand or is it "no good" becuase it has a hole in it.
Old 07-23-14, 07:49 PM
Houston204's Avatar
GE Genteq Round Capacitor 60 5 uf MFD 440 Volt Z97F9897 97F9897:Amazon:Home Improvement
GE is the brand many manufacturers use in their outdoor units.
Old 07-24-14, 04:51 AM
A
Thanks for your help!
It had a GE and I couldn't find one locally.
