Contactor ?
Old 07-23-14, 04:25 PM
Contactor
Our ac unit will not come on so I checked fuses no problems there, changed contractor and hit the reset and the unit comes on but as soon as I release the button it shuts off, I don't know what to check next any suggestions?
Old 07-23-14, 04:43 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! It is a "contactor", not a "contractor", which may be confusing some. Have you had the refrigerant checked by an HVAC person, yet?
Old 07-23-14, 04:48 PM
It was recharged last year and worked all summer. This was the first time to turn it on this year.
Old 07-23-14, 04:49 PM
Received 3,420 Upvotes on 3,066 Posts
You hit what reset..... a little pushbutton on a pressure sensor or you pushed in the contactor ?
Old 07-23-14, 05:04 PM
It is a rest on the contactor I push it down and the unit comes on and as soon as I release the button it shuts off
Old 07-23-14, 05:09 PM
Ok... that isn't a reset. You manually activated the contactor by pushing it in mechanically instead of electrically.
At this point you will need a voltmeter to determine where you are losing the voltage that should activate that contactor. One thing you can do is to check for a float switch somewhere in the white drain line near the air handler. You would see maybe two small wires connected to it.
Otherwise.... the contactor won't pull in by itself if the system is low on refrigerant.
Old 07-23-14, 05:13 PM
Thank you I will check. Thank you for your time.
Old 07-23-14, 05:14 PM
No problem....we're here to help.
