A/C Lennox HS18-261 fan issues
Old 07-24-14, 04:53 PM
My question is, is the fan on the condenser unit suppose to stay on while its on. The condenser sounds like its on but the fan wont stay on. would anyone be able to tell me if this is a big issue or a quick fix. Thank you in advance.
Old 07-24-14, 05:06 PM
Bob14525's Avatar
Received 11 Votes on 8 Posts
Yes, the condenser fan should be on as long as the compressor is on (they're wired in parallel). If the compressor runs for any length of time without the fan running, the compressor will overheat. The most common reason for the fan not running is a bad capacitor. Find the fan capacitor (the wiring diagram should help you locate it, or follow the wires from the fan motor) and see if it looks like it's bulging. If it's bulging (usually the top), it's probably bad, although it can be bad without bulging.
Old 07-25-14, 02:20 PM
Thank you for the info . I will look into it right away.
