What is the term for the "radiator" in a furnace and how do you replace it?
Old 08-10-14, 07:58 AM
Received 4 Upvotes on 4 Posts
The thing that looks like a car radiator is attached to the furnace via one main copper line that sends three (all ~3/8") copper lines to the radiator. Also there is another main line (~3/8") that branches out into three skinny copper lines (~1/4") that go way down into a deeper portion of the radiator.
Any ideas how to remove those lines and attach them to a new radiator? They don't appear to be attached via solder.
Thanks
Old 08-10-14, 08:45 AM
T
Received 31 Upvotes on 25 Posts
That's the evaporator coil and you cannot remove it until the refrigerant is recovered by a licensed HVAC technician. Unfortunately, that's not a DIY job, call your local HVAC company.
Why do you think that coil needs to be replaced?
Old 08-10-14, 10:43 AM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
I agree with Tom.
It looks like you have a hot water coil above the blower but the coil that you zoomed in on is an evaporator coil and should only be removed by a licensed HVAC contractor.
Old 08-10-14, 07:39 PM
hmm so now I'm wondering if it's simpler to just replace the entire furnace ... ? DIY-able?
Old 08-10-14, 08:54 PM
Houston204's Avatar
No, the same issue of refrigeration would apply.
Old 09-03-14, 06:18 PM
Thats an air handler not a furnace, it heats using your water heater, not the best system but better than a grill in the living room in the winter. Why do you think you need to remove the coil?
Old 10-09-14, 05:34 AM
So after more research, my options are to either pay ~6k for a new R-410 system (the existing one is R-22) or $1k to fix the coil and "refuel" the existing system.
Neither of these are good options for me so I looked into standalone AC units but the condo assoc says no, all windows have to be uniform from the outside.
Any other options (aside from sucking it up)?
Old 10-26-14, 12:50 PM
W
Ductless Mini Split . Probably a dual A/C & Heat Pump .
Does the evaporator coil have a leak ?
God bless
Wyr
Old 10-26-14, 10:20 PM
yes the evaporator coil has a leak(s)
