Frigidaire AC Window Unit
Do you have the owners manual? If not, Google the make and model number and have a look at the owners manual. It should tell you what the error code means.
Welcome to the forums.
The evaporator sensor is a little sensor attached to the coil or just in front of the coil but behind the filter. You'd need to check and make sure it's plugged in correctly. If it is.... replace it. If that doesn't cure the problem then the control board may be bad.
Frigidaire- Contact Us
