Thermostat upgrade
Old 08-16-14, 12:31 PM
Thermostat upgrade
Currently have a Evcon 3600-367P. Want to replace with a Honeywell RTH6500WF. Evcon connections are:
O blue
Y yellow
R red
X green
W2 white
What would my Honeywell connections be?
Old 08-16-14, 02:35 PM
Received 1,598 Votes on 1,473 Posts
Welcome to the forums.
Be sure to turn the power off to the air handler (inside unit) before changing the wiring.
O blue ---> O
Y yellow --- > Y
R red --- > Rc/RH leave jumper in place
X green --- > C
W2 white --- > Aux/E
1 --> 5
2 --> 0
3 --> 1
5 --> 5 or 9 ??
Houston, the forum pro, usually stops by and gives the best t'stat settings.
Old 08-16-14, 07:03 PM
What is the1-2-3-5 ? Not sure what you are referring to.
Old 08-16-14, 09:29 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
You must configure the new thermostat to match your system.
PJ has posted configuration settings for you.
5 May not appear since you have a heat pump.
Name:  Honeywell RTH6580WF heat pump.jpg
Old 08-19-14, 05:55 AM
My functions jump from #2 to #6, then #12. I can't get to either #3 nor #5
Old 08-19-14, 06:45 AM
Ok... then those settings are not required to be changed in your application.
