Is the white hole on the outside AC unit serious?
Old 08-17-14, 03:46 PM
R
Exclamation Is the white hole on the outside AC unit serious?
Hi,
I recently discovered that there is a white hole on the exterior AC unit. Is it series? If so, is it repairable or should I replace it with a new unit?
Here are some pictures of the mentioned white hole?
https://drive.google.com/folderview?...&usp=drive_web
Thanks for the help,
Robby
Old 08-17-14, 04:02 PM
It looks like the fins are just dented. It's not serious, unless it is leaking. Is the unit cooling?
Old 08-17-14, 04:30 PM
R
Yes, it is cooling, and I don't think it is leaking.
Will there be any problems later on, like the hole will enlarge or change size/depth due to outside weather?
Thanks,
Robby
Old 08-17-14, 05:36 PM
T
Received 28 Votes on 22 Posts
The fins are just bent, there's no hole per say. You can pick up a fin straightening tool at your local big box store and straighten them out in less then a minute.
Old 08-18-14, 06:13 AM
R
Thanks for the tip for the specific tool.
