Amana Quiet Zone -removing chasses from outer case
Old 08-25-14, 02:59 PM
I want to find out how many BTUs my air conditioner has- need to find the model number of my I believe 2000 portable Amana Quiet Zone AC. The only number I can see on the label without removing the chassis is the serial number. I called Amana and was told I need the model number to get information. I can't figure out how to remove the chassis from the outer case which I hope will reveal the model number.
I appreciate any advice.
Thanks!
Karen
Old 08-25-14, 03:26 PM
If I find the manual, which is highly unlikely, will that have the model number on it?
Old 08-25-14, 07:42 PM
Received 1,599 Votes on 1,473 Posts
The model number is not usually on the manual.
Doesn't that unit have a plastic plate/grill that snaps off the inside ? The filter would be behind it although you may not have to remove the plastic grille to change the filter.
The ID tag should be behind that plate.
