no power to thermostat connector on circuit board
Old 08-31-14, 03:43 PM
C
my circuit board in my unit burned up and i replaced it. i am not getting any power to the red wire terminal that sends power to the thermostat. I can jump power from the low voltage wire from the transformer and it will work
Old 08-31-14, 05:02 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
What do you have between these 2 points?
A fuse? float switch? duct mounted smoke detector? zone control board?
Old 08-31-14, 05:11 PM
Double check your wiring to the board. Does it have led lights?
Old 09-01-14, 11:28 AM
C
no led lights, the low voltage from transformer plugs into circuit board, goes through many different resisors and stuff, cannot follow, but no power getting to the power terminal for the thermostat on the board. the board is a ICM276 fan blower control
Old 09-01-14, 11:48 AM
Received 3,422 Upvotes on 3,068 Posts
Where does the transformer secondary (24) connect to the board ?
Old 09-01-14, 12:02 PM
C
1/3 of the way down on the left side, two connectors, yellow and common
Old 09-01-14, 12:12 PM
Are those the X and C connections ?
Can you tell me what the 5 terminals are labeled as.... T7=? , T4=?
Old 09-01-14, 02:18 PM
C
yes the x & c. the five are from left t7-y t4-r t6-g t3-c t5-w. t4 is power to thermostat
Old 09-01-14, 02:51 PM
Looking at the remarked board..... you need something to close the R to X jumper at the plug. I don't know what you have.... maybe a safety switch is open.
Name:  267 - Copy.jpg
Old 09-01-14, 07:51 PM
C
Thank you PJmax. those connectors went to the overheat sensor for my gas heater and it was tripped. must have had a surge when the board melted. working fine now.
Old 09-01-14, 07:59 PM
Great news...... well done.
