A/C capacitor
Old 09-02-14, 06:54 PM
G
A/C capacitor
Hello. I Installed a new capacitor about a month ago or so and today my Ac went out. I opened the unit and noticed the terminal C wire is fried. What could've caused this and what should I do next. Any help would be much appreciated. Thank you
Old 09-02-14, 07:00 PM
Received 1,601 Votes on 1,475 Posts
There seems to be a rash of that going around tonight.
Most likely the slide on connector that is/was attached to the wire was loose on the capacitor.
If the wiring is ok you can replace that terminal with a new one.
A similar issue to yours....
http://www.doityourself.com/forum/ai...or-wiring.html
Old 09-02-14, 09:30 PM
G
Thank you much. I will try to find a replacement wire for it and see if it starts up
