Question about condensor replacement.
Old 09-07-14, 07:37 AM
N
My 15 year old carrier 4 ton compressor went, I need to replace it. My friend has a goodman 13 seer r22 unit that is five years old that I can have for a couple bucks.
My question is, can I just replace the outside unit and use the same pipes and carrier air handler to get by for a while while I save some cash for a new high efficiency model?
Would it be a easy install?
Thanks for your opinion.
Old 09-07-14, 08:20 AM
N
Actually, I looked, the carrier was 19 years old
Old 09-07-14, 08:32 AM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
Be sure the licensed contractor that you get to install it also changes the filter drier and pulls a vacuum on the piping to the unit. I'd also recommend that the indoor coil has a TXV.
This would not be considered a DIY project.
