AC and Heat works well, blows appropriately; Exhaust fan doesn't turn on
Old 10-24-14, 03:35 PM
T
Question AC and Heat works well, blows appropriately; Exhaust fan doesn't turn on
Hi Everyone,
Purchased a home earlier this year. Phoenix, AZ; built in 1960. Has a newer AC unit outside.
AC and heater components work very well. However, when I set the termostat switch to the Fan mode, nothing happens. Seems rather odd to me since I presume the fan turns on during the AC and heat modes.
Any idea where to start diagnosing this? Have had issues with contractors recently, so I am of the mindset to do it myself where appropriate.
Will post specifics about termostat, AC unit and details that other posters deem relevant.
Thanks in advance
Troy
Old 10-24-14, 03:56 PM
Received 3,424 Upvotes on 3,070 Posts
Welcome to the forums.
Actually a very common problem. You will need to lift or remove the thermostat (not the base or wiring) and let us know what color wire is on which terminal.
Many times A/C is added to an existing furnace and there aren't enough wires to support the "fan on" mode.
