5 TON central AC breaker requirements
Old 11-13-14, 06:49 PM
I have an old central AC and not sure if its 4 ton or 5 ton but I am getting my panel upgraded and at the same time I plan to get the AC Breaker & its wiring upgrade to have it future proof as I plan to replace the existing AC with a 5 Ton Central AC.
Can anyone advise what sized breakers should I get installed (I am assuming most of the 5 TON AC's will have in same range).
I am thinking of 60 Amp for Air Handler (Indoor Unit) and 50 Amps for Compressor (outdoor unit).
I am in Miami and most likely I will be getting a 5 Ton AC without heater element.
Any help is appreciated.
Old 11-13-14, 09:14 PM
Received 3,420 Upvotes on 3,066 Posts
Welcome to the forums.
You can't guess on a breaker size. Each unit has it's own specs.
You can pre-run the wiring and install the breaker when you get the unit. You can most likely use 8-2 w/ground. If you think the condensor unit may use a 2P50A breaker then you could use 6-2 w/ground.
Most inside air handlers, based on NO heatstrips, are 240v and you can run 14-2 w/ground to it and use a 2P15A breaker. You could also use 12-2 w/ground if you like to be extra sure.
Old 11-16-14, 05:37 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
The mfg.will specify the the min. Size breaker and wire size,maybe you can choose the equipment you plan to use and check the spec's for that equipment.
Geo
Old 11-16-14, 08:08 AM
HVAC RETIRED's Avatar
First, you're guessing on the size A/C that is needed to properly cool your home.
The duct system & airflow should be evaluated as this is usually a major problem area affecting cooling performance.
Do a Free whole house load-calc: HVAC Load Calculation - Maunualj - Whole House Loadcalc
Print the simple instructions & follow them; NO cheating.
When you discover the right tonnage to be used, only then you can select a unit & get the correct conductor & breaker sizes.
