Control board fuse keeps blowing
Old 01-25-15, 11:47 AM
Don't mean to kick up old threads but i have kind of the same issue except reversed.
I have a Trane XL80 and my 3A fuse only pops when my heater is turned on. AC will run without popping it. It's been running since Oct. and now all of a sudden it's doing it again. I've tried a few things from someone who used to do HVAC but nothing was solved. It had done this before but i thought i had solved the issue, but its back. so any help would be appreciated.
Separated from...
http://www.doityourself.com/forum/ai...rol-board.html
Old 01-25-15, 12:43 PM
Received 255 Votes on 240 Posts
Sorry J.... that thread was getting too long. So welcome to the forums and your thread.
Old 01-25-15, 04:41 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
I would snap a picture or 2 of the thermostat wire connections, unwire and remove all thermostat wires from the furnace, then place a jumper wire between furnace R and W to prove if the problem is inside of the furnace.
