Calculating BTU requirement with heat sources
Old 04-11-15, 05:38 PM
B
I have an apartment that is around 34 metres squared for the main hallway, bathroom and living room. However, I am unsure whether I should take into account the bedroom as well. I can leave the bedroom door closed during the summer, but then can't I expect at least some, or quite a bit of heat to escape from the room through the door? The air conditioner would then be working harder for that if it does.
The second thing is the building I live in has a heating system that uses oil and is always hot. This means the service cupboard in my apartment gets very warm as there is always heat radiating from the main hot water / heating unit - and I can't turn that off. The maintenance guys have told me it is a very warm building because it was not built with ventilation for the pipework.
So how can I calculate how much extra BTU I will need for these sources of heat? The hallway, bathroom, and front room are about 34 meters squared. If I include the bedroom it goes to 47 meters.
By the way I will need to get a portable air conditioner. I already have a 9,000btu which is ideal for the bedroom size, but struggles anywhere else.
Old 04-11-15, 05:55 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Rough rule in normal non drafty home is 25 btu per square foot
Old 04-12-15, 11:51 AM
B
Hmmm, that couldn't be right for a portable air conditioner. I know the wall mounted or split ones can be more efficient, but with the method of calculation you gave me I should be able to cool the open plan living room / kitchen of my apartment with less than 7,000btu. With a portable air conditioner even 9,000btu seems leave part of the room a bit warmer than the rest.
I guess the issue is how many more BTUs do you need when you have a portable air conditioner?
I still don't know how I can account for the heat sources of this apartment in the calculations.
Old 04-12-15, 12:10 PM
lawrosa's Avatar
Super Moderator
sry I was thinking you wanted heat loss calculation...
There are free calculators to use online...
Free Air Conditioning Calculator
An HVAC pro should be better to answer your question.. Stand by...
Old 04-12-15, 03:02 PM
B
Yes, I tried some online calculators, but then they might be calculating for wall mounted which are more efficient. That particular one you linked to varies a lot depending on the insulation type. I do have good insulation but am really none the wiser. I guess these calculators don't account for people trying to cool particular rooms or area of the places they live in.
Old 04-12-15, 04:21 PM
D
Received 1 Upvote on 1 Post
If the 9,000 btu works well for your bedroom and not so well for larger rooms, then you know you need something larger than 9,000 btu. What is the area of your bedroom? What are the available sizes above 9,000 btu?
Old 04-12-15, 06:24 PM
B
OK, from reading elsewhere online I think it might be best to get at least a 14,000 btu and then run the 9,000 btu in the bedroom if needed which might cool down the rest of the apartment. The online calculators vary, but I just done one for my living room / kitchen which stated I need 12,000btu for that alone with two electrical units (pc and fridge).
The optons were 14,000btu or 16,000btu for not much more money. I was concerned that getting the 16 might be too big but it probably wouldn't be. Running two units instead of one seems to be the best idea.
Old 04-13-15, 06:35 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Efficiency has nothing to do with size when your talking about cooling
