LG Model Split Air Conditioning Cooling Intermittently
Old 04-21-15, 07:08 AM
I have an LG Split Air Con System - small vent unit attached to the wall indoors and larger fan unit outdoors.
It is blowing warm air most of the time, but the compressor comes on intermittently and blows cold air for a short period before reverting back to blowing warm air.
I've had a technician trying to repair it for days now.
The first thing he did was change the 'compressor'? Or he changed some part inside it, but it did not seem to have any effect.
After that, I noted how it was working: it was operating like this:
1) Warm air coming out.
2) Outside Unit Compressor Fan comes on for 10 mins,
3) Compressor starts.
4) Blows cold air for 7 minutes.
5) Outside Unit Compressor Fan stops and compressor stops.
6) Warm air coming out for 8 mins.
7) Outside Unit Compressor Fan comes on (cycle repeats itself from step 2).
The technician then came back and cleaned both inside and outside units, top to bottom with some kind of powerful compressed air cleaner.
Now, it operates in a similar fashion to the cycles described above, except now, it is warm MOST of the time, with the compressor and outside fan OFF most of the time, and only cold for a short while before going back to warm.
The tech is now 'guessing' that it could be a 'sensor' problem and is going to swap sensors over between my other 'working' LG air con unit to test it.
Another point to mention is that in the short time periods when it does blow cold air, it is not as cold as my other 'working' LG unit.
Many thanks for any pointers in the right direction to solve this problem.
Thanks,
Des.
Old 04-21-15, 07:50 AM
Bob14525's Avatar
Received 11 Votes on 8 Posts
Just to clarify, in 2), 5), & 7), you mention that the "fan comes on". Which fan are you talking about? The condenser fan on the outside unit, or the indoor fan (air handler/blower)?
Old 04-21-15, 07:53 AM
My apologies - it's the Condenser Fan on the outside unit.
Many thanks.
It's similar, but not an identical model to this one:
http://s3.supplyhouse.com/images/cat...egory/1668.jpg
Old 04-21-15, 07:54 AM
Received 267 Votes on 250 Posts
Welcome to the forums.
These split units are not easy to repair. They have sensors to monitor everything and they drift out of calibration or go intermittent.
You didn't leave a model number but most of those units have a diagnostic routine you can run thru or trouble codes that appear on the display.
Old 04-21-15, 07:58 AM
Model No: LG Model No. S10-S4A6EN
I live in South East Asia just now, and there aren't any English manuals unfortunately
No unusual indicator lights are showing - the appear to show normal operation - a green power light and a green 'outdoor unit' light, which goes on and off when the condenser is working (the small amount of time that it does work).
Old 04-21-15, 08:45 PM
Well you are correct..... there don't appear to be manuals in English. I only occasionally work on the LG units so without a service manual I can't really offer you any solid information.
