Buying Window Units
Buying Window Units
I am moving into an apartment that doesn't have central ac, so I have to purchase my own ac units. I am trying to decide between buying one or two units for the downstairs area.
The living room and dining room are each 9.4 w and 10.4 l. I wondering if I can get one ac unit with enough BTUs that can circulate both the living room and dining room.
My only concern is that the staircase wall will obstruct the airflow from the dining room to the living room.
That's probably a good move. Your dinning room may tend to be a bit cooler, but you should still get plenty of cooling in your living room.
I used to have a 10,000 btu window unit and it cooled my whole downstairs, which is about 800sqft and cut up pretty good.
I have one unit for the 3 rooms also, and it cools the whole floor, but I find I need to also run a fan, at times, into the living room and into the kitchen. That will help draw the cool air everywhere, when it's really hot.
I have a Vornado V-Flow fan, which does a great job in keeping the room cool on 60-70 degree weather days. Those are days where it's not that too hot, thus I can opt not to run the ac.
Put the unit in the room with the most heat load and blow it towards the other room. I like a/c units with side discharge rather then top. I feel they direct air much better. My previous house was about 1,000 sq ft, 10,000 BTU's in my main living area cooled the whole place nicely.
In your layout, I'd put the unit in the living room window.
I cool the entire 1st floor around +650-sf with a Half-Ton mere 6,000-Btuh window unit.
I use a 20" vertically adjustable Wind Machine fan you can buy at Wal-Mart.
Don't try to oversize the window unit as they don't circulate the air far enough away from the unit & it will constantly cycle off on its TH before the air get to the other room(s).
I turn mime's (TH) down low enough so it does not cycle off for a long period of time. Cools perfectly in the hottest & most humid weather you can imagine.
