Just change "A" coil
Old 04-30-15, 04:58 PM
Geochurchi's Avatar
Received 146 Votes on 134 Posts
Hi All, if an AC system is replaced with the same capacity (3 ton) can the "A" coil only be replaced instead of the whole Air handler ,which is in great condition,electric heat has never been used.
Thoughts
Geo
Old 04-30-15, 05:23 PM
Received 2,811 Votes on 2,543 Posts
You would need to confirm that the amount of air that the air handler moves is compatible with the new coil.
Old 05-01-15, 04:28 AM
Geochurchi's Avatar
Won't that be the same for any 3ton unit?
Geo
Old 05-01-15, 05:44 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Biggest issue would be warranty. Mixed parts normally get no warranty. Plus if this isn't a cased coil I doubt you will get a new coil to fit into the AHU.
