AC not working
Old 05-18-15, 03:37 PM
AC not working
Over the winter I installed a new thermostat. Everything went fine and the heat was working great. Now that it is summer time and it is time to turn on the air... it does not seem to work. It did work last summer, so I dont think there is anything wrong besides my wiring. Can you let me know what you see is wrong?
Size:  32.9 KBName:  T-Stat.jpg
Old 05-18-15, 03:45 PM
Bob14525's Avatar
Received 59 Upvotes on 50 Posts
The Y terminal is the "control" line for the compressor/condenser (outdoor) unit. There should be 24VAC between the Y terminal and the C terminal when the thermostat is calling for cooling. Unfortunately, I can't read the labeling on the thermostat connections, so I can't tell if the wiring is correct or not. Did you change any of the wiring at the air handler (furnace)?
Old 05-18-15, 03:50 PM
Thermostat wiring is as follows:
White - W
Yellow - Y
Green - G
Red - R
Blue - C
The only thing I changed on the furnace side was adding the blue wire to C. The blue wire was previously not used on either end.
Old 05-18-15, 04:30 PM
Bob14525's Avatar
Do you have a voltmeter? If so, what voltage do you read between Y and C when the thermostat is calling for cooling? Nominally, you should be reading ~24VAC between Y & C.
Old 05-18-15, 04:50 PM
I don't have a voltmeter (at least, not that I can find). I can hear the t-stat click when it is supposed to turn on...
Old 05-18-15, 04:55 PM
Bob14525's Avatar
Turn off the power to the furnace and remove the thermostat. Jumper the R, G, and Y wires together. Turn the power back on and see if the outside unit runs. If it does, it indicates that the thermostat is defective. There are separate relays in the thermostat to control the blower, heat, and cooling. While you're hearing a relay click, it's possible that only the blower relay (R to G) is closing.
Old 05-18-15, 05:11 PM
With those 3 wires together, the AC Came on... Looks like I am in the market for a new thermostat! Thank you very much for your help, it is much appreciated!
