Mini -Split system
Received 0 Votes
Mini -Split system
Anyone have this? I have been reading good reviews.This type of system is also called ductless ,used in other countries,Im debating of replacing my central refridge system with one of these.
Sized correctly for the space your trying to heat and or cool they work great.
Been around in the US for many years.
I have one in an 800 sq. ft. house I rent out and it's been trouble free for many years.
Super quiet and very cheap to run.
Very easy to install.
I don't have any experience with mini-split systems. As joecaption mentioned, they are quiet and efficient. My only concern would be repairability. I've seen a few posts on this forum from people with mini-split systems that have had problems. From the replies from the pros on this forum, it sounds like they are pretty complicated, with a lot of electronics (perhaps more than a typical split system like you currently have). You might want to research how easy or difficult it is to repair the system should you have a problem with it, particularly after the warranty expires.
Received 0 Votes
We installed a 13 SEER system 2 seasons ago for our living room / dining room . Love it & yes , they are quiet . :-)
Just installed a 16 SEER unit in our bedroom . So far , we like it even better . ( Newer technology . )
Buy the highest SEER you can afford . The heat pump - A/C models are only a few more dollars more than the straight A/C models .
God bless
Wyr
God bless
Wyr
