A/C unit disconnect wiring?
Old 05-27-15, 07:58 PM
Bought used mobile home. Tear down process while disconnecting A/C unit I observed wiring. 10/3 wire with grounds cut off for feed and THHN to unit. 2 black, 2 red, I know both hot,no need for neutral. There is a green THHN connected to middle bus and and the white wire of the 10/3 feed connected to middle bus. The white is also connected to the isolated neutral bus in the main panel. From what I know and researched this is wrong!! Why was it done this way and why us it working and shoukd i redo it?
Old 05-28-15, 04:13 AM
W
You have only one panel supplying the home & the A/C ?
If so , that makes it a service entrance panel . You probably have a green screw going through the neutral bar & threaded into the metal " can " ( enclosure ) of the panel . This , for all practical purposes , means that grounds and neutrals were terminated on the neutral bar . ( I like to add a separate ground bar . )
If there is a main before power gets to the panel , than the neutrals are on the neutral bar and grounds on the ground bar & no green screw through the neutral bar .
Let us know and I will reccomend corrective action .
God bless
Wyr
Old 05-28-15, 10:59 AM
Main disconnect is on pole. Then there is service panel in home. Neutral/ground are not bonded in the home panel.
Thx and God bless as well
Old 05-29-15, 01:39 AM
W
Then you should have 2 hots , a neutral and an earth ground coming into the house panel . You should have a ground bar screwed to the panel can / enclosure and the neutral bar should not be bonded to the panel can / enclosure .
All the earth grounds should be moved to the newly installed ground bar . Any white conductors being used as an equipment grounding conductor can be marked with green tape , at each end , to identify them as grounds ( and not neutrals ) .
God bless
Wyr
Old 05-29-15, 02:23 PM
Why would technician have cut grounds and used white as ground then connected to neutral in panel? Curiosity
Old 05-29-15, 08:54 PM
Received 3,415 Upvotes on 3,063 Posts
He probably didn't know any better. Unfortunately, some HVAC techs should not be doing AC wiring.
Old 05-30-15, 01:50 AM
W
I do not have any better answer than that , either . :-(
God bless
Wyr
Old 06-01-15, 03:44 PM
Lol kinda what I figured!!
