Carrier A/C unit not staying on
Hello,
I have a 4 ton Carrier unit that is over 20 years old. Besides obviously replacing it because of its age, I was wondering why its doing what its doing...
The a/c is blowing through the vents but not very cold. I look at the unit outside and the unit turns on for about 15 seconds and then shut off. It repeats this periodically. I replaced the filter but it did not help. Someone told me the compressor must be burned out since an A/C that old doesn't have low/high pressure sensors.
Also im in NJ. One repairman told me $3800 for Rheem and $4000 for a Carrier (4 ton each). That seems cheap. Should I be concerned?
What are your thoughts on the cause of the problem and solution?
